TwinTurbo.NET: Nissan 300ZX forum - Worn gear on cam that goes in cas? (n/m)
jlag
on November 04, 2011 at 9:34 PM
Thanks. I just tried that. I am reading about 23 degrees
posted by z32z
on November 04, 2011 at 09:18 PM
Does it matter which method I use to check timing.
z32z
19:34:58 11/04/11
My preferred method...
Stadsport (PHX)
20:25:45 11/04/11
z32z
21:18:10 11/04/11
Worn gear on cam that goes in cas? (n/m) -
jlag
21:34:30 11/04/11
2nd on the worn gear in the CAS. (n/m)
ZTicket(Dallas)
22:47:47 11/04/11
Yes, but I would expect an irratic timing. (n/m)
Draker (Eugene, OR)
23:02:22 11/04/11
Not always
Stadsport (PHX)
03:25:21 11/05/11
Timing is stable at 23 when at idle. When I give it more
z32z
09:38:18 11/05/11
No there is a part and procedure to replace.
Draker (Eugene, OR)
12:18:49 11/05/11
2nd, but I use a Renault plug wire :-)
Dark Diver
16:15:51 11/05/11
Spark plug wire I feel is more precise but have to unplug
craigz96tt
21:47:39 11/04/11
Do you have an aftermarket underdrive pulley ? (n/m)
jlag
16:11:57 11/05/11
What's base idle while checking timing? (n/m)
craigz96tt
18:38:14 11/05/11
Same here , run a high tension wire from coil pack 1
Xteam300TT (South Tx )
17:41:17 11/05/11
